no (radio-interface-config-command)
interface-config-radio-instance
Negates a command or resets settings to their default. When used in the profile/device > radio interface configuration mode, the no command disables or resets radio interface settings.
no <PARAMETERS>
Parameters
no <PARAMETERS>
no <PARAMETERS> Removes or reverts this radio interface‘s settings based on the parameters passed
Usage Guidelines
The no command negates any command associated with it. Wherever required, use the same parameters associated with the command getting negated.
nx9500-6C8809(config-profile-ap71xxTest-if-radio1)#no ?
  adaptivity                  Adaptivity
  aeroscout                   Use Default Aeroscout Multicast MAC Address
  aggregation                 Configure 802.11n aggregation related parameters
  airtime-fairness            Disable fair access to medium for clients,
                              provide access in a round-robin mode
  antenna-diversity           Use single antenna for non-11n transmit rates
  antenna-downtilt            Reset ADEPT antenna mode
  antenna-elevation           Reset the antenna elevation of this radio to
                              default
  antenna-gain                Reset the antenna gain of this radio to default
  antenna-mode                Reset the antenna mode (number of transmit and
                              receive antennas) on the radio to its default
  assoc-response              Configure transmission parameters for
                              Association Response frames
  association-list            Configure the association list for the radio
  beacon                      Configure beacon parameters
  bridge                      Bridge rf-mode related configuration
  channel                     Reset the channel of operation of this radio to
                              default
  data-rates                  Reset radio data rate configuration to default
  description                 Reset the description of the radio to its
                              default
  dfs-rehome                  Stay on dfs elected channel after evacuation
                              period expires
  dynamic-chain-selection     Use the configured transmit antenna mode for all
                              clients
  ekahau                      Use Default Ekahau Multicast MAC Address
  extended-range              Reset extended range to default
  fallback-channel            Clear the DFS fallback channel for this radio
  guard-interval              Configure default value of 802.11n guard
                              interval (long: 800nSec)
  ldpc                        Configure support for Low Density Parity Check
                              Code
  lock-rf-mode                Allow smart-rf to change rf-mode setting for
                              this radio
  max-clients                 Maximum number of wireless clients allowed to
                              associate
  mesh                        Disable mesh mode operation of the radio
  meshpoint                   Disable a meshpoint from this radio
  mu-mimo                     Disable multi user MIMO on this radio (selected
                              platforms only)
  non-unicast                 Configure handling of non-unicast frames
  off-channel-scan            Disable off-channel scanning on the radio
  placement                   Reset the placement of the radio to its default
  power                       Reset the transmit power of this radio to
                              default
  preamble-short              Disable the use of short-preamble on this radio
  probe-response              Configure transmission parameters for Probe
                              Response frames
  radio-resource-measurement  Configure support for 802.11k Radio Resource
                              Measurement
  radio-share-mode            Configure the radio-share mode of operation for
                              this radio
  rate-selection              Monotonic rate selection
  rf-mode                     Reset the RF mode of operation for this radio to
                              default (2.4GHz on radio1, 5GHz on radio2,
                              sensor on radio3)
  rifs                        Configure Reduced Interframe Spacing (RIFS)
                              parameters
  rts-threshold               Reset the RTS threshold to its default (65536)
  rx-sensitivity-reduction    Configure radio receive sensitivity reduction
                              threshold
  shutdown                    Re-enable the selected interface
  smart-rf                    Reset smart-rf related configuration to default
  sniffer-redirect            Disable capture and redirection of packets
  stbc                        Configure Space-Time Block Coding (STBC)
                              parameters
  transmit-beamforming        Disable Transmit Beamforming
  use                         Set setting to use
  wips                        Wireless intrusion prevention related
                              configuration
  wireless-client             Configure wireless client related parameters
  wlan                        Disable a wlan from this radio
  service                     Service Commands
The following example shows radio interface settings before the ‘no‘ commands are executed:
nx9500-6C8809(config-profile-71xxTestProfile-if-radio1)#show context
 interface radio1
  description "Primary radio to use"
  channel 1
  data-rates b-only
  mesh client
  beacon period 50
  beacon dtim-period bss 1 5
  beacon dtim-period bss 2 2
  beacon dtim-period bss 3 5
  beacon dtim-period bss 4 5
  beacon dtim-period bss 5 5
  beacon dtim-period bss 6 5
  beacon dtim-period bss 7 5
  beacon dtim-period bss 8 5
  beacon dtim-period bss 9 5
  beacon dtim-period bss 10 5
  beacon dtim-period bss 11 5
  beacon dtim-period bss 12 5
  beacon dtim-period bss 13 5
  beacon dtim-period bss 14 5
  beacon dtim-period bss 15 5
  beacon dtim-period bss 16 5
  antenna-gain 12.0
  guard-interval long
  aggregation ampdu tx-only
  aeroscout forward
  ekahau forward ip 172.16.10.1 port 3
  antenna-mode 2x2
  antenna-diversity
  max-clients 100
  airtime-fairness prefer-ht weight 6
  lock-rf-mode
  extended-range 15
  antenna-downtilt
nx9500-6C8809(config-profile-71xxTestProfile-if-radio1)#no channel
nx9500-6C8809(config-profile-71xxTestProfile-if-radio1)#no antenna-gain
nx9500-6C8809(config-profile-71xxTestProfile-if-radio1)#no description
nx9500-6C8809(config-profile-71xxTestProfile-if-radio1)#no antenna-mode
nx9500-6C8809(config-profile-71xxTestProfile-if-radio1)#no beacon dtim-period
nx9500-6C8809(config-profile-71xxTestProfile-if-radio1)#no beacon period
The following example shows radio interface settings after the ‘no‘ commands are executed:
 interface radio1
  data-rates b-only
  mesh client
  guard-interval long
  aeroscout forward
  antenna-diversity
  max-clients 100
  lock-rf-mode
  extended-range 15
  antenna-downtilt
